mattmoogus
If you find out the max clip level of your Firebox, you can make a pad to go between the mic pre and your interface. That way youll get the best noise performance.
M@
M@
Yes if you are doing quiet recording with passive ribbons you will need our Dual 99v or Micro1290 with there 80dB of gain. You can get 6dB more gain and a fully floating balanced output from the Baby Animal with a 1:2 output transformer like our JLM111DC.I would say that in 95% of recording situations the gain would be fine, but this wouldn't be my first choice for classical music or recording anything really quiet.
:grin: :grin: gotta like that.The two red LEDs in the back were an attempt to illuminate the JLM opamp so it could be seen glowing red through the vent slits in the side of the case (a la "pimp my pre..."),
No any value from 10 to 47uF will be fine as they are just extra power rail smoothing caps. The 100uF caps when they turned up were bigger than the measurement they gave use so we just went down to the next value so they fit better.One quick question: the BOM/schematic for the Hybrid shows two 100uF electrolytics, but the kit came with two 47uF. Is this correct, or do I need to swap them out for 100uF?
The baby animal will run on any smooth 48v to 62v rail that can supply enough current. You could use our AC/DC or PowerStation kits if you need more rails for other things but the 48v rail on them would only be enough for 1 or 2 baby animals. This is due to the pump charge and 47R 2w current limit resistor in the 48v rail. I will put up some very simple linear power supply ways to make the 48v to 62v for those with a distaste for Switch mode power supplies soon.Is my understanding correct that the Baby Animal needs to use the PSU supplied from JLM? Or is it possible to use an internal PSU
The baby animal will run on any smooth 48v to 62v rail that can supply enough current. You could use our AC/DC or Powerstation kits if you need more rails for other things but the 48v rail on them would only be enough for 1 or 2 baby animals. This is due to the pump charge and 47R 2w current limit resistor in the 48v rail. I will put up some very simple linear power supply ways to make the 48v to 62v for those with a distaste for Switch mode power supplies soon.[/quote]Is my understanding correct that the Baby Animal needs to use the PSU supplied from JLM? Or is it possible to use an internal PSU
That would be fine.I'd only be using one Baby Animal with phantom and also powering your DI. I guess that would all come off of the +48.
Only thing to be careful when powering several pedals from one supply it that they are all the same polarity. If they are say 9v boss pedals for example and use and a original fuzz face which is -9v and you run them both from the same 9v rail you will make a dead short. The fuzz face needs to run on a -9v rail so the ground can be shared. Also some pedals that run 15v to 24vdc actually split the rail into +/- rails with there ground sitting at half volts. So using one 0v ground power supply it will short out the - half of the pedals supply. This is only because normally all pedals are running on floating plug packs so the only 0v ground connection between them is the shield on the patch leads.Then I'd use the other for powering my guitar effects circuits, 6 of them to be exact.
