living sounds
I've got a problem with the LFO controlling the chorus of my Juno-60. This synth has two chorus settings, I and II, both stereo, as well as a mono setting (I and II pressed combined). As I understand it, stereo is generated by creating two LFO signals that are out-of-phase. The modulation frequencies should be set according to the table in the lower right corner of the attached schematic.
The stereo settings work as they should, and voltage swing and modulation speeds measure correctly. However, the mono setting is much too fast, and voltage oscillates only between (roughly) -0.1V and -0.3V, it should be 1.6V PP. I'm only measuring this with a digital multimeter, but in comparison to the other readings (which oscillate between around +- 9V) this is off.
I don't understand the theory behind the LFO schematic... How are frequencies determined? Is there anything obvious to check?
