sounds pretty dang cool!
I am more of a pedant than average. True the scientific definition of a "clone" involves an exact copy. Audio product clones are rarely exact copies, mainly because it's often not even possible, with component obsolescence etc.Sorry for be a pedant but if it's not the exact same circuit, then it's not really a "clone".
I’m happy your project is mature enough to have improvements!Summary of the notes / mods I did to the PCB/BOM for any other builders. These correct differences to the original Juno schematic and modify the bypass switching to work with a standard 3PDT footswitch
- the square is positive for the electrolytic caps
- R19/R24 should be 110k and R24 should have a 200pF cap in parallel (just solder the cap onto the resistor before putting onto the board). You get some robot noises without this.
- R81=10k, R86&R87=1.5k, R61&R62=10k,R9&R10 omit
- R84&R83 are 100k on the original schematic, but this increases the output gain quite a bit, I kept them at 10k, as in the BOM
- bypass switching:
This was my own solution to use a 3PDT standard footpedal switch with a LED indicator. (The designer used a momentary switch I think, but it did not work for me)
R66=100k, R49 omit, C17 change to be connected + side to R52/R56 junction (as C39 in original schematic), R47=10k, then the two sides of sw1 go to the 3PDT for the LED, and the -Va from the C17 round pad and C17 square pad go to the 3PDT (for ON)
Adjust for symmetric clipping - have you found the Juno service manual? Has the original schematic and info on calibration I think. I think there were some instructions with this board somewhere too. I used these trimmers from mouser PT10LV10-103A2020-PM-S.- What does the on board trimmer do and how did you set it? On the schematic it looks like some sort of feedback adjust for the MN3009.
I connected it to the pot pin1 of the depth pot, so the LED is the same intensity regardless of the setting- For the rate LED, did you connect it to the wiper of RV2 and ground?
banzai music- Where did you source the 2SK30's, SA1015's, and MN3101's?
Yes, log for audio, linear for the other two- Did you use a log pot for the input and linear for rate and depth? These are not specified on my schematic.
Did you change the resistors to 100k? The 'robot noise' is the BBD clock leaking through. The RC needs to LPF to cut it. I don't think the housing would matter if it is the BBD clock noise.- i made the 220pf// to R24 mod but still have an annoying noise that fluctuates with modulation rate (i guess thats what dmp called robot noise?)
