Midphase
Member
Thank you for this info. However in the "clone" schematic R67 and R70 don't correspond to the R83 and R84 on the original Roland schematic as far as I can tell. However in the clone, R75 and R76 do (I think) which would be a a match to the Roland ones as far as values.
I have been studying the Roland schematic, but it's a bit challenging to compare 1:1 since in the Roland schematic, the entire input section is assuming that a signal is coming from within the synth so there are no level adjustments, and even the depth and rate knobs don't exist in the original.
P.S.
"Are you using a log (audio) pot for RV5? What you are describing would happen if you used a linear pot (or you have a log pot wired backwards). "
I am using a LOG pot, but I do appear to have it wired backwards, I'll change that. This is one of the many things that I'm hoping to improve in my design, to make things a bit more clear for noobs like myself!
P.S.
