mrsoundb
Member
i have an LA-610 mk1 everything seems to work except the EL panel. I measured voltage on the EL terminals but I'm not seeing voltage at any gain reduction settings. What part of the circuit drives the panel? What would cause it to not receive power? I removed it from the circuit and turning a light on and off shows gain reduction from the photoresistors, so it seems that the only part of the circuit that drives the panel is bad. Any advice is appreciated.
