Here is an update on the resistor. It is actually a 1k ohm resistor. Although the one in my unit was a 1/2 watt, the tech at Universal Audio said I should replace it with a 1k ohm 2 watt. He also stated that i should replace it with a carbon composite resistor.
The resistor in this position is found only on UA LA-2a's (not older Teletronix units), it serves to reduce the inrush current surge and extends the life of the 1st power supply filter capacitor and the rectifier diodes. Prior to heat discoloration, the color code on the resistor was brown, black, red, gold. This has been confirmed, so it is definitely a 1k ohm.
What is a good source for carbon composite resistors?
