Technetium
Active member
ok,
i'm in the home stretch on my la2a. i dont have the T4b yet, but its passing audio, & outside a ground hum sounds great.
now that there are no more archives to search i have to ask some simple questions...
1) i bought a power supply that has no CT for for 6.3v secondary, i so i have 2 100ohm resistors going to ground. questions is, how are they oriented? i.e. one from each leg to ground, or both from the same leg? does it matter?
2) i also changed the topology to fit it in a 2RU case, so in order to be able to follow DJ's book, i DIY'ed a turret board from lexan & brass screws. it has 9 rows of 3 screws, replacing the (9) 3pin terminals (which i #'ed from 1-9), & 7 rows of 2 screws, replacing the (7) 2pin posts(that i #'ed from 1-7). i then followed DJ's wiring directions, keeping in mind CJ's list of errata about the book.
my question here is this: all pin 2's of the 3pin blocks should be run to ground, as well as all ground pins on posts 1-7, right?
i mean it seems like a simple question, (almost a stupid one) but i wanna eliminate the possibility of foolish mistakes before i rack my brain trying to find where this hum is coming from.
any help would be greatly appreciated,
thanks,
-dave
p.s. its great to see everybody reconviene @ the new TT home. u barely even missed a beat. it would have been a real shame if it all splintered after leaving RO.
thanks,
-dave
