david.uulf said:Thanks Duantro and Saxmonstor you guys are the ducks guts will order mine soon
i was rereading the tread last night and came across the post about mounting the stuff that goss under the little amp boards on the the under side of the main board about a hour to late :'( oh well i guess that is why you make a prototype before the main run. :-[
I mounted the stuff on top under the amp boards. The trick is how you solder in the mill-max sockets if you got the ones in Mulletchuck's Mouser cart. Look through my pics on page 21 and you will see how to solder the sockets so there is room underneath.
