peter purpose
kato said:But it had to be done...
Could have been a little gentler you vicious bastard..!!
zayance said:So the can is silicon glued or Epoxy? seems like epoxy for the mess...
kato said:Ianbryn11 said:any news on a complete parts kit available? Just ordered the Hairball trafo kit...
I have enough overstock to assemble 4 or 5 kits. PM if you're interested.
$40 shipped (international additional) for all components, including relay, mill-max pins, etc. All quality parts. The electrolytics are low-impedence, high temperature, ceramics are C0G, etc. Same as I ordered for my own builds. Parts will be individually labeled with component designations for the LazPro pcb.
edit: you'll still need the T4b parts, transformers, and knobs.
edit for slight downward price adjust.
Sammas said:Is it a Universal Audio T4B?
I'd be more concerned about the gunk holding the LDR's in place. Can you get them out without damaging them?
I got these parts in... the sockets work fine. I don't think the pins are worth the money - a little short and don't fit the holes well. It would be better to use the cut ends of diodes or some such. The pins need to be long since there are components under the boards.20 X SOCKETS FOR 1MM PINS 575-029200 0292-0-15-01-06-27-10-0
20 X 1MM PINS 575-311720 3117-2-00-21-00-00-08-0
janvanvolt said:Okay, t4b received from kenetek, and put all parts apartnow it's mounted on the LA3A :
Just to get the last open things solved:
- If i have standard LED's how to i correctly solder them on the 3 pads ?
- Any trim instructions for RV31 and RV23 ?
- News on R13 ?
dmp said:20 X SOCKETS FOR 1MM PINS 575-029200 0292-0-15-01-06-27-10-0
So if you're interested in paying out the wazoo for notoriously inconsistent cells, you can!We show some in Obsolete stock, but I'll have to get a hand-count to know exactly how many we have left. The current price is $25 each with a factory minimum of $250.00; when these are gone, there won't be any left in the world.
peter purpose said:PG = Power ground... to one side of the bulb.
MP = Meter power... to the other side.
Have the ldrs touching the el panel.
Winetree said:I find it physically impossible to mount RV23 and RV31 because the front mount pots are in the way.
Is this correct.
Sammas said:Are you sure you have the right kind of trimmers? They need to be the horizontal variety.
