mitsos
- Joined
- May 4, 2007
- Messages
- 2,886
I have an LA4 that I've recapped and swapped the audio 4136 for 2x OPA2604. Sounds fine and compresses "to spec", but the GR meter is WAY off. I've calibrated it checking the I/O voltage, and the compression is working 100%, it's just the metering that is off. For example it might be compressing 5dB but showing 20, that kind of thing. In fact, the needle almost always shoots way to the left, even with small amounts of GR. This is in GR mode, VU works fine.
My guess is the two opto units (LEDs or LDRs) are not well matched to one another. I suggested to the owner that we swap the 2 optos for a dual vactrol which will be cheaper (or at least faster to get done). The LM301 seems to be working, I think. If I were to test the optos, I guess I would have to remove them, apply the same current to the LEDs and measure resistance in each of the LDRs? And then vary the current and measure again?
thanks!
thanks!
