Howdy Gents,
Here is a draft of my next design front panel.
The EQ is sort of based on Ian's Helios 69, but with a fixed 60Hz low boost and 75Hz cut. Mid frequencies are Neve 1073. High is 10kHz. All boosts and cuts are stepped in 2db increments. Makeup gain will be the same schematic as the preamp section, except with a 12AU7 instead of 6072 in V1. V2 is 12AU7 cathode follower.
Compressor is LA2A with all of the radio-era stuff removed (stereo link, preemphasis, etc.). Will be 12.6 vdc, so using a 12AQ5 in place of 6AQ5. Also, gonna do the CJ Mod with 12AY7.
There are still a few things to add...
1. EQ and Compressor "in/bypass" switches.
2. Clearer labels for the EQ and Compressor sections.
3. A +4/GR switch (but, c'mon, does anyone really use anything other than GR?)
Questions:
1. Does it need a "EQ before/after Comp" switch? Am thinking of just having it wired up to be EQ after Compressor, but I'll consider it if everyone thinks it's a deal breaker.
2. Who likes the LA2A "limiter" switch?
3. Any other suggestions? Design-wise, or graphics-wise?
Questions:
