moamps
Yes. The reference voltage should be very stable and arbitrary on level. Higher ref. voltage is better, IMO.seva said:12v!? I you have to increase input to ref!?
VR1 is the input adjustment. The reference is not 24V, it's about 4V. The resistor string is about 10k and the voltage divider with the 47k (R32) gives about 4V.seva said:Is VR1 to increase the rectified input signal to the 24v ref?
Or is VR1 to decrease ref V to rectified input signal?
Typically I would use about 10k.what is a good value for the hole ladder R? I choose 51k for the calculation attached. Is it OK?
Because that's what I had available! The LED's are in series, so they need about 16V, to which you have to add about 2V for the CCS.Why do you use 24v for your power supply?
You can't put 30 LED's in series; that would require about 60V, which the comparators cannot handle. You have to arrange them in strings of 8 or 10. So you would need about 20V for strings of 8 or 24V for strings of 10. I would use strings of 8 because the comparators come in quad packs.What is the minimum for 30 LED´s with 40dB range?
I believe they are +/-17V, the audio rails.seva said:what is the voltage of v+ and v- of the trident high res meter. Also 12v? same psu?
It's D&R Triton. Power supply gives +/-18V, at strips it drops to +/- 17,5V.seva said:what is the voltage of v+ and v- of the trident high res meter. Also 12v? same psu?
It depends of the used opamp/comparator.can i leave comarator legs open when i need less then 4 in any stage?
LM139/239/339 are all the same beast except guaranteed temperature range. I use LM339 in PDIP14, but you may want to use an SMD version that would take less real estate.seva said:I found
LM 239 DIL
is that the right comparator?
R31 is a dirty trick that reinjects a fraction of the input voltage into the reference. The result is the response is in the form (ax+b)/cx+d), which is an hyperbolic.seva said:what is the value of R31 in your meter schemo? why is it na?
Input is at the top of VR1. The signal is rectified elsewhere.seva said:3. Abbeys schemo shows connection to the input back.
Not "trident", it's Triton, from dutch manufacturer D+R.seva said:still not understand why the trident goes to ground.
R1 is there to ensure DC path to ground when the TL074 is missing. Just there for troubleshooting purpose.seva said:OK- Now, I see it thanks Abbey!
But I mean R1 - 100k goes to ground. I don´t know why. Other circuits don´t have it (or not?)
Seems ok, but your pic is hard to read, not enough resolution.seva said:OK
Do you think V+ V-, gounding and combining stages is ok- How i did it?
