> I always thought RMS was the average and that's that...?
Note that in audio, "Average" is average of the absolute value. A high-passed waveform always averages to zero. That's not interesting. As you said, we rectify (get the absolute magnitude without polarity) and then average. Obvious to analog-heads, but some algorithm-geek may jump right into AVG() and wonder why it don't work.
RMS inherently loses polarity info, no rectifier needed (altho many practical implementations need a rectifier because their "square" is one-quadrant).
As you know, average is Sum/count and RMS is heating-value. When heating, the high parts count more than the low parts, since heat is square of voltage.
In bench-meters, a $10 meter measures Average, a $20 meter may read Peak-peak. Both are marked (or scaled) so that on SINE waves they read the usually-cited RMS number. The Avg meter has a 1.1 multiplier, my P-P meter has a 1/2.828 divider. But a True RMS bench meter costs $100++, because it has to have a squaring-chip (or heater/thermo) to give actual RMS of arbitrary waveforms. (And even then, any practical True RMS meter has a Crest Factor specification, higher crest-factors won't read right.)
A sine wave is often sold as RMS, the Average is 0.9 times RMS.
A one-sided square wave which is zero V half the time and 2V the other half, averages to 1V, but heats like 1.4V.
Here is a lopsided clipped sine showing Ave about half of RMS.
It is trivial to devise odd waveforms to give odd Avg/RMS ratios, if you enjoy confusing your meters.
However if we high-pass an asymmetrical wave the ratio is different. A very narrow positive spike, hi-passed, gives Avg/RMS near 0.13.
Since DC is not an interesting sound, just makes trouble, we always have some DC-block, a high-pass, somewhere in the chain.
But your singer isn't trying to confound the Avg/RMS ratio. The Avg/RMS ratio of most speech/music will be less than 1 but probably greater than half, and fairly consistent over any long run of mixed music (not pure synth-tones/noises). I would guess 0.8. It isn't very important. Long-term reading of speech/music is inherently sloppy approximation. Level is bopping up/down constantly. And even if we believed that RMS=Volume, I know I could set two different tracks to identical RMS readings, and they would not sound same-loudness.
It isn't precision. When you cut from music to news, or from newsroom to remote, you don't want level to change "much", like -10dB to -30dB. But you can cut-over from -10dB to -15dB and the listener tolerates the level shift. You get the general level generally similar. And an Average will be as good as an RMS except for very abnormal sounds.
