OK, I've managed to clear the fault by replacing one of the DRAM chips, with 4116.
The error code was E91 and the leds on the function buttons indicated that the bit in error
was the first one (Pgm 1). I replaced U1 which is the low-order byte, lowest significant bit and
all is fine now. Unit powers-up with no error codes!
If a E92 error is shown, the faulty chip is in the high-order byte, and depending on which led is
different, it is U15 - U22; with U15 being the lowest bit (Pgm 1 led) and U22 being the highest
bit (Pgm 8 led). This applies to the plain 224 (not X, XL).
A big thank you to wtmnmf for all the help!
PS: a_)_i , have you had any luck with yours yet?
