scott2000 said:What's up with D3?/// Pic making it look funky??/
morls said:I'm wondering if it could be something to do with C86? This doesn't appear in the schematic, but it is in the parts list as part #
240-00614 description CAP,ELEC,47uf,16V,RAD
The cap I have there is polarised, and I replaced it today, but there is no +ve marking on the board so I went with my photographs as to the polarity.
Thanks Scott. I think it was backwards - looking at the data sheet the +ve of C86 goes to pin 27 of U8. Have replace U86 according to this. Issue remains.scott2000 said:Always a chance you can have it in backwards...
SAA7360 data sheet attached......
morls said:Thanks Scott. I think it was backwards - looking at the data sheet the +ve of C86 goes to pin 27 of U8. Have replace U86 according to this. Issue remains.
morls said:Thanks Scott. This "foldback" distortion might be what I'm hearing. I'll try replacing the transistors, if I can track them down.
Khron said:It wouldn't be the first time ceramic caps crapped out, or transistors failed / got noisy.
Khron said:I don't suppose tracing out that part of the circuit (ie. lifting the schematic) is feasible, is it?
I don't think there's a need to. Between the MPX schematics and the SAA7360 Application Diagram I have the info I need.Khron said:I don't suppose tracing out that part of the circuit (ie. lifting the schematic) is feasible, is it?
