NewYorkDave
Here's something that could be useful for you guys who wanna mix out of the box using your outboard, etc. It's for when you need capabilities beyond those of a simple passive mixing box, but don't need a full-featured console.
NOTE: THIS IS NOT A READY-TO-BUILD PROJECT. THIS IS JUST THE OUTLINE OF THE CONCEPT. But I think it could be fleshed-out into a nice project.
PDF
As noted, coupling caps are not shown on the schematic but may be needed unless you can achieve and maintain very low offsets. If the mix busses are physically long or otherwise possess significant capacitance, it may be wise (for the sake of stability) to insert a low-value resistor in series with the inverting input of each mixing amp. The PFL/Monitor section could be essentially the same as the output section shown, with the necessary switching added at the input of the mix amp.
The prefade buffer is unity-gain and the post-fader amplifier gives 10dB of reserve gain, since the fader is usually run at 10dB of loss. The output amplifiers are also configured for 10dB of reserve gain. The panpot is my own variation on the usual dual-pot design; I've mentioned it here a number of times. It has performance advantages over the standard configuration, but at the cost of 6dB minimum loss. This loss is made up in the mix amp.
I was tempted to add subgroups and the like, but my intention was to keep the project basic and compact. I think this could lend itself to PCB-per-channel or PCB-per-group-of-four construction, with separate master section PCBs. The builder could configure for as many channels as desired, up to reasonable limits.
