bluebird
I'm trying to save space on the pcb I'm working on. I was looking at SMD versions of the LM317 and figured the through hole version laying down flat on the circuit board would probably be able to dissipate more heat than any of the SMD versions. Maybe an aluminum standoff instead of a nut on the screw that ties the LM317 down.
I'm only powering a couple op amps and a few relays. I'm dissipating about 1.2 watts with the LM317, full load 100ma, 10 or so volts in/out differential.
Does anyone see why I couldn't just lay the IC down on a pad of copper the size of the LM317 its self?
