dinsen
Member
- Joined
- Apr 13, 2021
- Messages
- 7
This is my first post, but I've been lurking for a while.
I'm restoring a Soundcraft Spirit Studio console for my daughter and a core part of the project is building a new power supply as the original was missing.
I chose an LM350T for the positive 17V rail and a LT1033 for the negative rail. The LM350T, however, has failed twice for me, and in a rather unpleasant way as it short circuits which sends roughly 33V onto the 17V supply line I want to understand the failure to ensure it doesn't happen again.
I chose to build the resistor/capacitor/diode part on a stripboard, and this is one potential source of problems as I suspect a short circuit of the regulator could damage it. I like strip boards, but I realize they may not be too great for power supplies as the distances between the strips are easy to short. I suspect perhaps peice of metal let inside the box from drilling could have caused a short. The LM350T is reportedly a tough component but looking at the internal schematics in the data sheet shorting the ADJ pin to either IN or OUT is likely to damage it. I cannot detect any short circuits nor see any metal in the box, so there's no smoking gun - it's just a hypothesis.
Being a trained engineer, I of course devised another theory: The power supply has about 1.5m of cable to connect it to to the console. Also the console has lots of 47uF decoupling capacitors inside, plus about one metre of additional wiring inside. My circuit has the usual protection diodes from OUT ->|- IN and ADJ ->|- OUT. I fitted no protection diode from +17V -|<- GND, as I didn't think that should be necessary. Theoretically however, inducing a current in the cable could perhaps cause problems... I've done some simulations in LTSPICE, but nothing that reveals any real problems (perhaps a little if I simulate the self inducatance of cables 1500 km long!), so I doubt if that could be the cause of my problems.
So I clearly needed a third theory, and I was thinking that perhaps the LM350T's I bought were bad. I just checked the numbers and they both seem to have the same batch numbers as some tested by someone on youtube (video below). I did not buy them from eBay, but from a decent supplier here in Denmark, so I'm kind of surprised if this is the issue.
We would appreciate opinions and experience from all you experienced builders - should we give up our stripboard design, include protection diodes, or find some original LM350T's (or even better some LT1085's, but they're expensive and harder to find)
Best wishes from Copenhagen,
Anders
Anders
