mikep
You consider look-ahead to eliminate the need For infinitely fast attack (diode clip) to ensure no overshoot. A usefull way to think about fast attack time in a limiter is to relate it in terms of a number of periods at a frequency of interest, namely the high frequenncy limit of the band. Perhaps 4 cycles at 20khz for a minimum look ahead of any use? Thats 200us. Perhaps a series of all-pass networks could work.
The problem is the AUDIO frequency part. If you do the calculation for an RF look ahead limiter the necessary delays can be achieved with a length of transmission line: some coax or a spool of fiber (optic) can create quite a long delay, relative to the period of the waveform at high frequencies
ok how about this: a diode clipper with an adjustable knee that is varied by the instantaneous slew rate. Faster slew would cause a softer knee.
