jdbakker
lagoausente said:mm, C8,C9 aren´t the caps you tell? 100n between + and ground, - and ground. Are not them? Aswell as C17, C18?
It's not (just) the caps, it's the placement, layout and the routing.
JDB.
jdbakker said:lagoausente said:mm, C8,C9 aren´t the caps you tell? 100n between + and ground, - and ground. Are not them? Aswell as C17, C18?
JDB.
rodabod said:[Dials DIY bullshit police] "Hello? Hi, yep.... Yep, I've got some serious busllshit going on in a thread here. What? Opamps? Yep, it's another opamps thread.... No, they haven't mentioned their favourite caps yet."
jdbakker said:JD 'FFS' B.
Hah!
lagoausente said:Well, a whole world inside only opamps behaviour and interaction in the circuits..
Another shorcut question, from what slew rate usually are opamps considered "fast opamps". Aprox.., or just looking at the seller label?
JohnRoberts said:lagoausente said:Well, a whole world inside only opamps behaviour and interaction in the circuits..
IMO slew rate stopped being an issue for audio opamps since the 553x and TL07x families came out in the '70s(?). For good performance when working around digital circuitry that can generate much higher than audio frequency noise, I suspect gain bandwidth is more important than power bandwidth (slew rate) for maintaining low source impedance. Also power supply rejection vs frequency now becomes an issue with higher than audio frequency PS noise possible.
