M50 aluminum membranes
Thanks guys. I have a very old M50 that needs a new diaphram. I just need to check the thickness of the aluminum and tuning freq, I have the old diaphram which is extremely thick so I just want to check that this is really correct and the tuning freq. so I can save some time
BeezKneez did a copy of that capsule; here's their post about it:
Thanks K Brown. My capsule is from 1952 and the spacing between membrane and backplate is machined into the capsule. I have replaced it with mylar but it does not sound as good.
Diaphragm thickness of the aluminium version is 8 micron. Tuning freq is probably as high as possible. I know that for the first version with pvc diaphragm the resonance frequency of the whole system was 15khz. But it also had a different frequency response than the later aluminium one.
FWIW, this post claims 0.7 micron, though they mis-identify it as nickel (there never was a nickel one).
I know Tim already knows this, but for others following the thread - though they share the same aluminum capsule, many sellers of KM 53 will say pop an APE on one and get virtually the same sound as an M50; I'm convinced that the biggest contributor to the sound on the M50 (and M49) - other than the capsules, obviously, is the particular, huge transformer used, which the KM 53 does not have; the AC701 contributing far less to the mics' sound. Decca were quite content to convert their M50s to FET, but would never have replaced that juicy transformer.
Not surprising - as you can see on the Saturn Sound diagrams, the construction of the Mylar capsule was completely different from the one with the alum diaphragm, with also very different spacing.
Don’t forget the headbasket. And in the M50 the capsule is flush mounted in the sphere. The kk53 in the km53 has a gap between capsule and housing as far as I know.
Well I know that the nickel capsule was 0.8 micron but the aluminum diaphragm that came on my M50 capsule mounted on my MM2 measure a whopping 60microns thick which I cannot understand.
Hmmm . . . plus that image doesn't look like any of an actual M50 capsule that I've ever seen; including the post, which is supposed to be 2-pc rubber; no part of it was that long, or solid metal as that appears to be. Almost seems like the entire capsule was replaced with one from a measurement mic.
K Brown this is the earliest version of the M50 capsule. Neumann produced it from 1948 -52. This is a Neumann MM2 microphone built for anechoic chambers. Only 90 of them were ever built. Mine is no.50
@k brown, which transformer is in the M50?
