M7 Capsule in Apex 460 schematic/desig ?!
should work fine. biggest issue you'd have is finding a rubber bumper long and stiff enough to hold the caspule in the right place in the basket and maybe the capsule voltage being too high depending on the m7.
sollte gut funktionieren. Das größte Problem wäre es, einen Gummipuffer zu finden, der lang und steif genug ist, um die Caspule an der richtigen Stelle im Korb zu halten, und vielleicht ist die Kapselspannung je nach M7 zu hoch. Okay
ok ist a "ali express china m7" with no data sheet.. you think the 60v capsule may be 2 high.. ?!
60v is pretty normal; the issue is that the stock Apex 460 power supply applies up to 80v to the capsule, which is a bit on the "spicy" side.
M7 ali express capsule works great in my SCT2000 with a 120V tube PSU.. only the level output ist 7-9 db lower as with the original sct2000 tbone capsule..
