the matter is that MA1 has several holes in the input trasformer zone since MA1 can accept several input transformers as many diy preamps, so may be an easy mistake there.3nity said:Does it work the same with condensers and dynamics?
I see the pcb in dual sided, did you make sure to let some space between pcb and transformer?
mus1k_freak said:Good news, Victory! 8)
The issue was the input transformer, the cinemags are NOT compatible with this pcb, as it shorts the ground on the casing to the output of the transformer, so to get it to work i soldered in a cm 2480 backwards, input from the phase flip switch and output across R21. worked like a charm, its a really quiet and dark mic pre, but i think paired with the right mic and source it could definitely sound great, hoping to get it all put back together and try it on some guitar tracks tomorrow. thanks again for all the help and support! next time ill just use the transformers suggested
thanks for posting,pachi2007 said:- Cut trace between C4&C8 and make the solder joint as in the picture (2nd ver. pcb). Does anybody has the picture? How can I make sure mine is the 2nd v pcb?
