Mackie CR1604 Schematics
welhamm
New member
Hi
I'm currently attempting to repair an old Mackie CR1604 (not VLZ) mixer which has issues with the main outputs (no Left output). The only workaround to this is to use the Solo output to the monitors. I've also noticed the BNC 12V output is dead.
Does anyone have the schematics for this unit handy? The only ones I can find are for the VLZ version
Thanks in advance!
welhamm said:
Hi
Thanks in advance!
If you go to Mackie website.....  Schematics-mixers-classic........it looks to be there????
Hi
Thanks in advance!
Hi! I know you posted this 7 years ago, but I just got my hands an a mint condition (cosmetically at least) original Mackie CR-1604 and I'm having the same issue as you, no left output. I was wondering if you solved the issue and what the problem was. Seems like it could be a common thing, or just an odd coincidence.
Jed
Jed
He has not been online since 2017 so don't expect him to respond.
It’s probably old caps that have dried up. The powersupplycaps were bad on mine and the phantom was noisy. Also some coupling caps in the output section were bad. The switches/pots need cleaned , and you may need to reseat/clean some ribbon cable connectors. I did this last year and it fixed everything.
Thanks Fazer, that sounds about right... I did a thorough test last night and the left bus insert point does work (it feeds the left output) so the problem must be before that point on the circuit board. Setting up a table where this thing (and all of it's screws) can live for a week or so 🔬
