scott2000 said:
I figured I'd add to this that the C300z crossover works with the Srm450 v1 just fine. and fits where the old amp plates go...
https://www.fullcompass.com/prod/272691-mackie-0012545-crossover-with-input-plate-for-c300z?gclid=EAIaIQobChMIl9_6heW53QIVBTBpCh1yjAFFEAQYASABEgJSdfD_BwE
Excellent.
Only thing is the connector is reversed for the drivers.... Yellow is HF + Blue is LF+...
That´s the right way to do it.
Crossovers shift frequency so much at the crossover point , typically one by minus 90 degrees, the other by plus 90 degrees, that at crossover point thay are 180 degrees from each other ...
perfect out of phase, which produces a severe notch at that frequency.
So the practical solution is to invert phase from one of the drivers, and inverting HF is safest option.
Just running 300 watts/channel old QSC amp and they sound pretty good..... The 300z crossover is different than the 300 schematics posted earlier and it doesn't have the protection circuitry..... The sound is definitely not as harsh as the original plate amps.... but a bit looser I guess... . I definitely recommend them if you haven't got yours going yet......
I was chiming in to suggest exactly that.
I live in Argentina where every commercial product is available, Mackie, JBL,you-name-it but because of distance freight is horribly expensive and Customs Tariff is high .... plus going through all the bureaucracy and red tape.
The end result is that commercial products come in (same paperwork to bring 1 or 1000) but **spare parts** do not, so there are
many orphan blown amp powered cabinets all over the place.
Standard and very popular solution is to junk unrepairable/unreplaceable original plate amps, close gaping hole with a piece of plywood , and mount 2 speakons and a passive crossover on it, then power the now passive cabinet with some classic Rack mounted power amp, from old but trusty Peavey CS800 to QSC to no name Chinese ones.
Surprisingly end result is quite good.
2 precautions:
1) don´t drive them with more than, say, 250W or 300W (tops) per cabinet.
Original Mackie built in preprocessor has tons of limiters, variable high pass filters, voice coil current sensors (predict voice coil temperature) , etc; NONE of that is present in the oldschool cruder approach.
IF the power amp has an anti-clipping limiter, by all means activate it.
2) since passive crossover has NO protection at all, PLEASE add a car type lightbulb in series with driver.
A 12V 15W one will protect most common drivers, any size.
In the specific case of SRM450 they have a stronger 44mm voice coil which stands more power (not 150W by any means) so you can use a larger lightbulb, a truck type 24V 30W to 45W should do.
Unprotected drivers will die on the first high pitched microphone squeal.
As I said above, passive cabinets sound very good, just don´t ask stupid high SPL out of them.
Here it´s very common to see, at small Rock Festivals (say a neighbourhood one played in the street or a Club by non Pros) some small PA company with, say, 10 to 20 such speakers, mixed brands and models, a veritable salad, bought dead for cheap and recycled.
Let me tell you that 10/20 recycled ones beat the dust off 2 or 4 "original" ones any day of the week
