clintrubber
W.r.t. 'making iron work', what do you all do to get this going and in a controlled fashion ?
Thinking of output-TX secondaries that could easily overdrive DAW-inputs I figure it's nice to have some drive-control before the output-TX (it's usually already present as the mic-pre gain), then on to the linedriver-&-TX and then a simple passive volume control & then to the DAW-input.
What do you use ? How do you control the amount of pushing ?
(BTW, I figure the route as previously mentioned here of using a clean clean clean micpre and treating with iron after the recording has taken place would give the most control, but that'll be sidetracking the thing above too much).
Peter
Peter
