Category 5
I need to build an attenuator that will reduce the output of my soundcard by about 50dB, and at the same time make the output appear as a 150 ohm load to the preamp.
My thinking is that the only way to get accurate frequency, noise and distortion measurements is by way of such a device.
I can crank my soundcards output to -43dB and get the level I need, but it is very close to the noise floor at this point so my noise measurements are useless. Also, since the souncards output isn't 150ohms I believe the preamp isn't giving frequency and distortion measurements that would correlate with it's performance while using a 150ohm mic.
Any simple way to build such an attenuator and load dummy into a balanced 1/4" to XLR cable so I can use the cable to get reasonably accurate measurements?
Thanks as always!
Shane
Thanks as always!
Shane
