Michael Tibes
My beloved 70s 1959 is having a problem I am stuck with: while everything seems fine when idling or at low volumes, one side of the power tubes runs hot (glowing red) when it is pushed hard.
I found that without input the bias is stable at -42V at both pairs of EL34, but when it gets pushed it might get uneven, roughly around -50V / -70V if I remember right. I say 'might' because I checked it several times on the bench, but didn't write down the exact numbers - and now that I want to post it here the problem seems to be nearly gone - now it's -57V / -61V and the tubes seems roughly equally hot! So the problem is also intermittent
Any thoughts on that are much appreciated - the amp is still in nearly original condition I don't want to simply swap parts to see what happens but keep it as original as possible.
Thanx,
Michael
Thanx,
Michael
