steppenwolf
Hey did the bridging rectifier ever get replaced?
This amp uses tube rectification. I swapped the tube and tried solid state rectifiers, but that didn't help...thanks again!
I don't have the energy to go back thru this thread and catch up with progress, but I have a JTM45 in hand for the next 2 days, if there is anything you would like me to check I can, I have an oscilloscope but no sine wave generator.
I recently read an article (I think on the Bogner site) that says, that every wire and every component radiates a magnetic field that can cause positive or negative feedback and can dramatically change the sound even though it is not a real malfunction...
I even read that the earliest Marshall used small wires that caused a capitance to ground. They said that could have contributed to the mystical JTM sound.
That's to much voodoo for my right now... :shock:
All of that is why we keep harping on you about lead dress. The problem is not necessarily something that's on the schematic--parasitics are different from amp to amp due to lead dress. When I got my Deluxe fixed I can tell you that the changes I made were very minor.
Don't exchange sockets and parts willy nilly. You're just wasting your time. You need to cut those cable ties and start rearranging the wiring from the board to the sockets in the PI and power tube area. Start with moving the grid wires on the power tubes up and away from everything else (above the board, not around or underneath it).
1. install grounding buss, bare solid wire that goes from each pots ground lead and then the input jacks.
remove jacks and clean any corrosion while you are in there.
check rersistance of all grounds. set onmmeter to lowest range, tie one end to chassis with clip, go around and check every ground. anything over 1 or 2 ohms is suspect.
don't forget to dis regard test lead resistance.
check output trans grounding. check sec ground connection.
check speaker ground(see weird idea in earlier post)
2) move output transformer. you might have coupling going on. move it while playing, see if you can find a better location.
even hor to vert can help.
reinstall series grid resistors closer to socket.
shorten up leads, so only resistyor body is between socket pins.
1/4" can make a difference.
shorten wires in all grid circuits. go thru the amp and shorten every wire.
(pins 2 and 7 of 12ax7, pins 5 on 6v6,6l6,el34, etc.
3) install series grid resistors. starts with smallest value that stabilizes amp. if 2.2 k stops it, try 1.5 k.
go all the way up tyo 10 k.
mount resistor body directly up against the solder lug, as mentioned before.
When measuring at the junction of the 0.1uF caps and the 220K resistors, whilst varying the volume with a sine wave source, I get the following;
-47V DC to -50V DC on one side
-47V DC to - 65V DC on the other side
A little surprised this was not more balanced
A JTM45 is dirty at the best of times, the sine wave starts to distort and kinda twist around half volume and then squares off at high volumes.
I dont get the high frequency crap riding on the sine wave, that you have seen.
Let me know if there is anything else you want me to check.
Where did you scope it, at the output or at the anodes?
I put a thick grounded aluminum plate over the amp when measuring, sadly it doesn't change anything. When the amp is mounted in the cab, is there a metal plane on the guts side to shield rf? you may need a sheet of metal, or foil on a piece of wood placed over the chassis when testing out of cab.
I don't think the scope gives me a wrong reading as I can actually hear the problem as well...For the O-scope, use a ground lift on the power plug for working on equipment with multiple grounds. Gerald Weber does have some good info, damn good salesman aswell. I used to be on page 100 of one of his books.
Didn't you mention in an early post that you discconected the pre to the PI and fed another preamp signal into the PI and it worked OK?
Sorr
You might be right...But that was the only problem I could actually see...Glad you haven't given up on this yet. Since you have data from another person with a functioning amp that has the same bias thing, I think you should be looking elsewhere.
When I broke up the connection between Preamp and PI and fed the PI with an external signal, the problem was still there unchanged. When that nasty oscillation thing is happening, there is no change in the preamp waveform (except some drop in level when I push the power amp but that should be due to B+ sag). The Waveform after the PI has this oscillation, too, but when I disconnect the negative feedback, the waveform is clean there but stays weird at the anodes and at the output.I was thinking about your earlier experiment where you broke out the preamp to PI connection and tried to isolate the problem that way. Isn't it possible that the problem is parasitic and disappears when you break that connection?
When you get the thing to misbehave do you see any unusual behavior back in the preamp stages?
