> So with say a INA134 receiver on the input - a buffer of some sort would still be needed after, before goin to the PGA ye?
Why? What is the difference between an INA134 and an OPA2134? To a first approximation, both are low-Z outputs. And in this specific case: I think a INA134 is a OPA(2)134 with some standard resistors in the package, so they are the SAME at their outputs.
> then again on the output of it... Like implemented on this page:
He has a good, to him, theoretical reason to buffer the PGA2310 output. Personally I think it is a frill: few loads are really 600Ω, and as good as the 5532 is, I'm not sure why we want an added step of distortion, not to mention complication and board space.
SIMPLIFY: If your source is unbalanced and reasonably low-Z (1K is no big problem), and you are not obsessed with triple-oh THD numbers (board layout can degrade THD more than the test-specs suggest), then just use a naked PGA2310.
> say you were going for a fully differential path, using one PGA for left and another for right, do you think that they would track reasonably accurately, differences between two chips?
Tracking specs are on the datasheet.
