CurtZHP
Does anyone here have any experience with MCI JH-series machines?
I have an MCI JH-110 that I suppose is beginning to show her age.
Fired her up for the first time in a long while and racked up an alignment tape. Ran into a couple hopefully minor issues.
1. The high-frequency repro adjust on the right channel basically tops out well below 0VU (around -7). I swapped repro cards between channels and the problem stays with the right channel, so I might be able to rule out the card.
2. There seems to be an intermittent issue with the tape counter freezing up. At some point the numbers stop counting and none of the controls for that work at all. A power cycle appears to fix the issue for a while.
Fortunately, I have the complete service manual for the machine, but I thought before I dive too far into its guts, I'd see if anyone else had some tips first.
