MCI JH-500 Racking
msheriff123
New member
Los Angeles
hi all! i’m new into this forum and i’m currently working on racking up a few channels of MCI 500 pres/EQs
this is the first racking up project i’ve taken on and i’m wondering what type of line input transformer was used on the original console. If it’s a 1:1 transformer, what was the ohm rating for it? and if i were to use a transformer with a higher ohm rating (still 1:1) would it be an issue?
thanks!!
Looks like a 2:1
+4dBu is attenuated by 9.5dB for nominal operating level (-5.5dBu). 2:1 gives 6dB attenuation and there's a 3dB pad after the secondary (330r/820r). Taking into account losses that seems right.
Reflected Z at input would be about 5k.
It would nominally be 5k:1.2k, but I suspect the spec would be something like 4k:1k or 10k:2.5k.
A decent xfmr accomodates easily +100%/-50% mismatch.
Using a 1:1, you'd have to change a couple of things: R71 from 330r to 1.6k and R70 from 9.1k to 27k.
That would be a 10k:10k.
