I was hoping for a electrical schematic,
What more of an "electrical schematic" were you hoping for, that is
NOT visible in
Rob's post, right here?
And you seem to stubbornly refuse to even mention what sort of damn connector your mic has - that in itself kinda waives the right to complain or have that sort of attitude...
This is the wiring diagram of a Beyerdynamic M201 (with the RLC filter removed, for clarity). This is about as close of an "electrical schematic" as you can hope for. One was not shown earlier because i'm sure it was deemed much too trivial / simple / obvious.
The big round doohickey at the left is the voice coil; the squiggly line top left is the
humbucking coil. The pin numbering corresponds to the XLR standard.
thank you for being dismissive and not giving me any way to research this further
There's not much left
TO research. Repairing a microphone voice coil is no small feat, especially with the wire being maybe a quarter the thickness of a human hair, or even less, so unless you REALLY know what you're doing, AND you're (or at least "feel") qualified to remove the diaphragm without tearing it to pieces, repairing the voice coil wire (if it's even feasible), AND gluing the diaphragm back in its place, with the voice coil well-centered and not rubbing against either of the pole pieces........
No way of becoming an expert at something without learning about it beforehand.
Well, there's "learning", and then there's "being taught"...
Do you by chance have any good papers/articles or whatever in regards to Hi-Z transformers in microphones
https://www.coutant.org/578probe/index.html
Scroll down just past the image with the frequency response. That's an example of a mic with an isolation / step-up transformer (ie. even in the "low impedance" setting, it still puts out more signal than is provided at the input).
https://sengpielaudio.com/MD421HNoderHL.gif
Second wiring diagram from the right is the case for the MD421 HN or HL. Those use a "klein Tuchel" / DIN output connector, and are an example of high/low impedance output
without an
isolation / step-up transformer. Pin 2 is "common"; low-impedance output (straight from the voice coil) is available between pins 2-3; high-impedance output is available between pins 2-1.
