My thoughts were around the acoustic interference's to the capsule more than the headbasket integrity. There must be some reflections going on in there.It always cracked me up that Oktava copied this body almost exactly for their ML-51 active ribbon mic (side address, of course).
But, my thought exactly, that the bar is strictly for structural integrity.
I'd guess a 'side benefit' rather than the primary purpose.I always assumed it is to reduce plosives, like strapping a pencil* in front of a microphone.
(*Maybe showing my age with that one).
I've heard of this too, it's one of those weird sounding tricks like using something like gum on the back of the front teeth or dental wax to help with sibilance.I always assumed it is to reduce plosives, like strapping a pencil* in front of a microphone.
I imagine this may be the reasoning. As I remember, the MD421 was known as a 'Bass' microphone, for bass drum, bass cabinets, etc...Although it sounds great on live vocals and designed for that use maybe?I always assumed it is to reduce plosives, like strapping a pencil* in front of a microphone.
I liked them on toms, especially floor, but stop using them as the cymbals (like ride that close to floor tom) get awful harsh crosstalk in the upper midrange (to my ears).the MD421 was known as a 'Bass' microphone, for bass drum, bass cabinets
The mic is not strictly designed for low end rich instruments. It is designed for extended response which also makes it suitable for bass heavy instruments.
These mics are primarily intended to be used for broadcasting - much larger target group. I remember playing with these literally as toys back in the 80's as my mother used to be a journalist at national broadcasting station. They were used a lot for field recording with portable tape machines.
The construction is very complex, and that bar in the front doesn't affect the sound much. It can't really be compared to condenser mics construction wise. It covers tiny area of the diaphragm, as it's center is already covered with a resonance disk. Only outer part of the diaphragm is exposed to direct sound. The bar is too close to the diaphragm to be affecting the sound signifiantly.
There used to be a sphere available for purchase in order to stop the plosives. So the bar isn't there for that reason. It doesn't cover the outer, exposed part of the diaphragm which is sensitive to plosives.
Here's an interesting video.
Yes, that one too. The main reason I posted is that I'm experimenting with the DIY concept of making dynamics into classic bodies/headbaskets. The TLM dynamic I'm making has the headband as well, in front, I wonder if this would be significant to the response. These do sound very good IMO...I have added felt to the base of motor now btw to cancel reflections. There is a Shure xformer in the base.. . . and the RE15!
I know, right? These are for live use so maybe the null would be increased(?) if they were positioned 'incorrectly' somewhat, reducing pa feedback. ?Boy, the looks you'll get pointing that end-on at the talent! ; - )
