b2
Hi, :grin:
I've just finish a tube preamp with a EQ stage (the Gyraf Pultec EQ).
I used a 12AT7 instead of the 6922,the caps are Wima and the inductors Toko (22,47,100,100mH).
I've done measures,last night with A Neutrik A1 system.
Gain max 58dBu wihout EQ
Gain Max 57dBu with EQ
Frequency response 60Hz at -3dBu to 28Khz at -3dBu.
Level of the signal inside the preamp=0dBu
LOW FREQBoost
1-----28Hz at +4dBu
2-----35Hz at +8dBu
3-----45Hz at +10dBu
4-----55Hz at +12dBu
5-----65Hz at +12dBu
6-----ALL frequencies from 60Hz to 28Khz Boost to +16dBu??????
LOW FREQ Cut
I take a point at -16dBu
1-----50Hz
2-----75Hz
3-----100Hz
4-----140Hz
5-----160Hz
6-----I don't know......
HIGH FREQ-Q=Max-Boost
1-----2.2K----Q=0.48------+5.5dBu
2-----2.9K----Q=0.43------+5.5dBu
3-----3.9K----Q=0.6-------+5.6dBu
4-----7.5K----Q=0.6-------+5.8dBu
5-----12K-----Q=0.6-------+5.8dBu
6-----16K-----Q=0.65------+5.8dBu
HIGH FREQ-Q=Min-Boost
1-----2.2K----Q=0.28-------+4dBu
2-----2.9K----Q=0.28-------+4dBu
3-----3.9K----Q=0.38-------+4dBu
4-----7.5K----Q=0.41-------+4dBu
5-----12K-----Q=0.43-------+4dBu
6-----16K-----Q=0.45-------+4dBu
HIGH FREQ Cut
I take a point at -16dbu.
1------5.6K
2------7K
3------9.3K
4------11.4K
5------12.5K
6------21K
Well, I don't know if this measures are well right....I tried with a 6922 inside this Eq sections,the Frequency response was very very nice from
30Hz at -3dBu to 28Khz at -3dBu.
The Boost was increased max +15dbu in the LOW FREQ section but still around +6dBu in the HIGH FREQ section.The FREQUENCIES were the same.When,I listen my preamp....NO HUM,NO 50Hz HUM very quiet,nice sound with the 12AT7,still neutral and the Eq section do is job very cleaned with this tube.With a 6922 inside very good sound,more impression in the Bass,with Eq on than the 12AT7.
Well,I hope my comments,and those little work,is perhaps interesting for the community. :grin:
A+,B2.
:thumb:
LOW FREQBoost
1-----28Hz at +4dBu
2-----35Hz at +8dBu
LOW FREQ Cut
1-----50Hz
2-----75Hz
3-----100Hz
4-----140Hz
5-----160Hz
HIGH FREQ Cut
1------5.6K
2------7K
3------9.3K
4------11.4K
5------12.5K
6------21K
A+,B2.
:thumb:
