Fred,
reducing the possible "movements/vibrations/resonances" of the capsule seems important to me...
that's why i don't like the rubber design...
do you think that it could better or more efficient to transmit the vibrations absorbed by the capsule, into the viscoelastic layer ?
i agree, but as i stated before i don't see that from a practical point of view this is wise: if the mic fall from mic shockmount the rubber stand does flex and allow to dissipate a part of the energy.
The flex can be huge, and the capsule may hit the grid from headbasket as i already seen (broken sadlle mount in u87ai, but astonishingly no marks on the headbasket or other parts of the body!).
This is one of the reason you see a white plastic 'cap' over the capsule, it serve to transmit the shock energy to the backplate and not to diaphragm or the fixing ring and help protect them.
But yeah, if you want optimal (ideal?) sound captation i do think you need an
isostatic condition.
I don't understand what you mean by 'transmit vibration... into viscoelastic layer": the dampening don't have a direction, it works bidirectionnal.
As i see it, the vibrations you are worried about are
airborn transmitted (produced by the spl of the sound source), and i don't see how you could deal with that without impacting soundwave captations of capsule.
The CLD idea is more to help isolate the capsule from structural born vibrations, so
solid transmitted through the body parts.
As pointed this could be from the ground/mic stand/ cable (solid vibration transmission) but from airborn source too ( mic body parts resonnance from exposure to high SPL source).
I do see your point about the capsule isostatic condition but for the topic's subject (try to improve stock chinese mic) and for the moment i would prefer to stay with 'typical' capsule mount system as it may be used by most.
From an ideal theorical point i do think you may be right.
MS Vienna:
The best way is to try out the options in question and judge the real world results. Even better - have it judged by various good sound engineers in their working environment (alpha & beta testing). Otherwise it is too easy to get lost in theory.
100% agree.
Just look at mics with simple mechanical construction that sound very good e.g. U47 and C12.
I do agree with Fred, those are no so simple mechanical construction. I find the chinese mic to be much more simpler in their structural point. This may or may not be easy to improve them and as you stated, only real world implementation will tell 'the truth' (and if possible objective observation of outcome).
Thank you for explanation about " the concept of impulse transmission". Totally make sense.
Banzai,
directly hit wires, capacitors, whatever, in a switched on microphone. If you don't hear noise when you tap, the item isn't causing any microphonics. If you tap and it rings, you have a problem. You can go through a whole mic like this, and solve every issue one by one. It's lowtech, but works.
that totally make sense too (as your comments about whole structure versus material with wire. I must admit i like lowtech solution... probably because i have always complicated answers and idea...
The other problem is too soft, and the capsule will hit the headbasket when there's a shock or when you move the mic. Too hard, it keeps the capsule from hitting, but it won't damp any vibrations.
I'll add too that that if too soft or too hard there is not ideal damping of vibrations: most (if not all) 'suspended' damping system are tuned. They do have an efficiency range which is dependent from mass and shore hardness.
Maq3396,
Can someone please post pictures of capsule mounts that they feel offer superior or excellent isolation?
This is not as easy as it seems. It'll depend from your end goal. For example the Elam/c12 mount is not absorbent at all. In the case of the Elam it seems (to me at least) this have been taken into account in some of the electronic choices made too : read the Thread about Brauner VM1 mod: the grid resistor is low which mean filtering of low end content, T14/1 is low core transformer so low end is reduced and the mic to be vocal oriented... not many low end acoustical contents in that case, so insulation of capsule is not as critical from low end point of view. And if you add to that the multi chambered internal construction with much less resonnant material than metal... all this contribute to the choices made about capsule mount in my view.
Try the same type of capsule mount in a K47 equipped u47 mic body could lead to very different result... Well, i suppose...
Do you have a 3d printer accessible? If yes this could be very interesting at a moment or an other.
