bcarso
Hmmmm.
In sim this amp has some crossover distortion of a disturbing character---it could be nominated for an award for Most Improvement Under Output Current Loading. Without something pulling down (or up) the spectrum has predominately odd-order components that go out almost indefinitely, peaking somewhere around the 23rd (!). This is for the conditions Av = 2, Rf/Rdiv each 1k, 100mV peak in at 1kHz. This is with no loading other than the feedback network itself.
And yet the net amount of all this is still fairly low at about 0.01%.
Meanwhile I'm still not sure of the compensation components, but with C3 600pF and C1 1nF there is a big peak at 340kHz.
If the output is loaded to the neg rail with about 5mA things clean up distortion-wise, but then the peak sharpens and reaches almost delta 40dB. Ouch.
I guess the aim of the designer was to avoid any quiescent dissipation in the output devices---it's the only advantage that I can see to the output configuration.
Brad
Brad
