clintrubber
Was toying around with the circuit in a simulator and in the meantime all these fine (re-)discoveries turned up. Nice.
What I found of the 'old' circuit:
(FWIW, but since I already typed it down offline here it is anyway)
Some sim-toying around, with totally different transistors, so all this VERY FWIW.
Conditions: +/- 15V, internal caps initially held at 630p/10p/10p and feedback-cap 200pF.
Gainsetting-resistor 220...22k & feedback-resistor 22k. Load-resistor 20k.
* DC: with a single diode for D2 the output devices Q6,7 don't conduct
* an AC-sim comparison showed the influence of the single vs double diode for D2:
while there's some peaking @ 2MHz for the double-D-situation for gains of 20dB and less,
it's not awful.
At 6dB gain it's only a few dB.
For the single-D-situation the peaking is more severe and decreases in freq
for higher gains.
Like:
"7dB @ 1.2MHz for 6dB gain" down to "2dB peaking at 200kHz for 40dB gain".
Identical D-vs-2D-comparison for 6dB gain with C3 boosted to 470pF as per Jeffs suggestion:
For the single-D-situation the peaking is some 8dB @ below 200kHz
For the double-D-situation there's even some more (~10dB) peaking, @ 350kHz
More detailed analysis will be of little use, my transistors are not even close etc.
I might have gone already too far with this present sim-setup.
I only continued with it after seeing the peaking was in the same ballpark as the previous simulations of the fine people here.
Good to hear the double-diode is being confirmed, thanks Rafael.
Transient-sims show that the THD-residual is now virtually absent, i.s.o. nasty for the 1-D-situation (Bcarso already commented like this). And the output-devices are now actually conducting i.s.o. wildly switching around.
Haven't checked yet, but it sounds like the corrections can easily be added to the already built PCBs.
Regards,
Peter
it's not awful.
for higher gains.
Like:
Yes please, would be great - that'll bring us all on the same page again.Those were the only changes. Let me know if you need me to make another schematic with the changes I´ve listed.
Regards,
Peter
