"In a gooseneck condenser microphone in which a condenser microphone unit is supported via a support pipe including a flexible pipe, the shield in a flexible pipe part is enhanced. In the condenser microphone including the condenser microphone unit and an output module section provided with a circuit board for outputting audio signals in a shield case, the condenser microphone unit being supported on the output module section via the support pipe including the flexible pipe, and the condenser microphone unit being connected electrically to the circuit board via a microphone cable 40 having a shield covering line 43, which is inserted in the support pipe, at least in a part of the microphone cable 40, which part being installed in the flexible pipe 31, 32, the shield covering line 43 is exposed, and the part of the microphone cable 40, which part being installed in the flexible pipe 31, 32, is brought into contact with the flexible pipe 31, 32 at many points."
