Hi all.
So, awhile ago I came across a recording class in which the author, amongst other things said the following:
1. The mic's best position is perpendicular to the source (which of course he said is next to impossible to set up).
2. The next best thing is the mic angled at 45 degrees to the source (pic 1).
3. The mics should all be positioned in axes parallel or perpendicular to each other (pic 2).
4. If possible and unless you know what you are doing, avoid eq while tracking as it may usher in phase issues.
I tried this approach and got to say I was stunned(!!!) by how much better the sound was and how much clearer individual parts sounded, yet with a clear and coherent stereo image.
So, two main questions popped right after:
1. Why angle the individual mic at 90 or 45 and not just any random angle? Why is it that these work the best?
2. Why position the mics in the fixed axis fashion? Why did it work best that way?
3. Eq or not, while tracking?
While I was happy with the result, I cant get over my mind about how many things I have yet to understand.
I tried to find info on the matter but had no luck at all. I have some books on mixing and recording but none of them contain even a single line remotely connected to the way mics work, especially in relation to each other.
I even contacted some schools who offer classes, but curriculum is mostly around post editing and staff (...).
I want the understand these basic engineering principles, as I feel they are key to becoming better.
Anybody care to share any info or resources?
Thank you, everyone!
