freespace377
New member
Greetings, all.
I noticed this bbd about a week ago when a friend turned me on to the shure 57 xfmrless thread.
I decided to join just now, so I could post this, to disagree with a person I came to have great respect for in reading the '57 thread, namely, CJ.
So jumping in with both left feet,
CJ said:
"So a positive grid signal turns into a negative plate signal, which is applied to the cathode. Since the cathode and grid are, in effect, moving further apart, the voltage between them is increasing.
This means the input signal has become bigger because of the feedback.
What kind of feedback is this?
Positive or negative?"
Here's how I look at it:
The signal goes through the "common cathode" stage and is inverted. It is then applied to the cathode, where it goes through the tube in "grounded grid" mode, being amplified, but not inverted, and summed with the inverted signal at the anode.
Seems to me that has a degenerative, not regenerative effect, que no?
Variations of this are used in phase inverters for SE to P/P.
Of course all the talk is resovled by IO telling us what happens to the amplitude of the signal when the feedback is applied.
Be gentle, its my first time.
Dan
Dan
