The idea of 'marrying' to an equalizer is absurd to me. -And if this were for a rock/pop situation, an EQ that is "suited" to vocals is unlikely to be an EQ which is suited to -for example- bass guitar. -or piano -or guitar... and so forth.
Hence, imposing the limitation of 'marrying' to an EQ is -in essence- silly, to me.
Likewise, If I'm using a ribbon mic at a distance, I would LOATHE the idea of being tied to the same mic preamp as if I were using a U47 on a kick drum.
I mean... who on earth needs to have things 'decided' for them.
You buy these components in separate boxes, and then if -down the road- you discover that your frequency of use suggests a different common combination, you sell whichever you want, or buy an alternative. -The idea of 'tying' yourself to one of each seems unnecessarily restrictive.
Now I'm not saying that you CAN'T make a record with all one preamp and all one EQ, -I made dozens back in the day- but if you're beginning from an 'a-la carte' proposition, build what you like and go from there... If you build it into one box however, it seems to unnecessarily limit your options.
