Tubetec said:It kinda does look better in the third version you showed , but Id take the version with the extra gain positions in the lower range anyday , I often find with my tube mics that I need less than 30db gain on loud signals, I often use line input for mics on high level sources too ,upping the input impedance means less load on the transformer and slightly cleaner performance at high levels .
There is a 20dB pad that will extend the range down to 10dB gain. There is also a line input.
