Mic preamp remote control
Larrchild
Fort Lauderdale, Florida
Hello all. It's been about 10+ years. Hope you are all well!
Yeah that's me. No more Fairchild clones as the ITB trend continues but darnit, they still need a mic preamp! So I took a push-pull tube design and gave it remote control and recall with an ESP 32, motor pot and relays. Runs from a browser. I think digital control of analog is the future. Who's with me? lol. Seriously, an industry standard for data exchange might be useful. -larry
    241.9 KB
The DAW I use (Ardour) can accept Open Sound Control messages for remote control. Possibly AES70/Open Control Architecture might be a possibility as well, a lot of the network connected audio devices support that now.
The OCA Alliance has a demo board and code called OCA MicroDemo that runs on a ST 32F215 using FreeRTOS and lwIP to show that you can make a fully compliant AES70 device with a microcontroller (since a lot of the AES67 audio-over-ethernet devices have relatively heavyweight hardware available some people may assume that you need that much horsepower).
H Bridge on the motor with PWM ramping.
Is it usable real time or only for dump recall due to EMI/RFI ?
I drop PWM for analog driver in my automation/recall design, motor too noisy.
I even implement a driver bypass after few sec of automation inactivity to erase any load on the motor, save consequent current consumption and dead quiet, fader wake up in 2 or 3ms if any change in position value.
Nice project you have
Zam
Zam
I moved the PWM up to like 100 kHz to keep it out of the audio. Worked! No extra sounds when you adjust.
Hi Larry ,
I had an idea about making a tube compressor but instead of going to the trouble of building the control amp ,virtualising it instead , so sort of in the box and out of it at the same time .
Sending control signals by varying the PH48 up or down a bit was something I had been thinking about for a while ,microcontrollers I really dont know much about . Phantom has it own built in limitations in terms of current so what you can put on a mic pcb in terms of space is all very well , but what phantom can actually supply is a bit meagre .
Very interested to hear more about your audio analyser and transformer testing software .
