Svart
you've fooled us!
:green:
Sorry couldn't resist!
:green:
Basically yes, note however that the inductance is much lower than the value I recommended which makes the filter somewhat less efficient at least at lower frequencies. You might want to quickly run a simulation to check for roughly flat frequency response with the new value.Would the CM filters described in the following datasheet be suitable for the transformerless designs?
The CMRR of the overall mic pre will be (as a first-order approximation) improved by the differential gain of the additional gain stage as this gain stage has unity gain for CM signals; you cannot restore that advantage with trimming. If the CMRR of the differential amplifier is limited to say 80 dB (trimmed or untrimmed does not matter) the overall CMRR of the mic pre will be 140 dB at 60 dB gain and the configuration as shown (of course there's always a second-order effect which limits things but they tend to be benign IME at least mid-band). If you re-arrange the topology the overall CMRR will be reduced by the gain of the second (or rather now third) stage. Check the CMRR curves of those IC instrumentation amps, they nicely show the gain-dependent CMRR.Is there any particular reason why you have the diff amp stage after the second gain stage?
jcharles00 said:sorry for the necropost, but i notice the pdf's in the initial posting no longer work. any chance they could be re-posted?
jdbakker said:jcharles00 said:sorry for the necropost, but i notice the pdf's in the initial posting no longer work. any chance they could be re-posted?
That happened in the transition to the new forum software. You can fix them by hand by copying the links and removing the string "www.groupdiy.com/" from them. For example:
http://www.groupdiy.com/www.sg-acoustics.ch/analogue_audio/microphone_preamplifiers/pdf/A_r1.pdf
should be
http://www.sg-acoustics.ch/analogue_audio/microphone_preamplifiers/pdf/A_r1.pdf
HTH,
JDB.
JohnRoberts said:[quote author="bcarso"]The Motorola process for the 4403 was very much better than others (see the curves in Motchenbacher and Fitchen). I don't know whether On Semi has preserved the tradition. Amusing that they were merely trying to make a switch, and had no interest in low noise.
Not to sound like a Toshiba commercial, but the rbb' of the 2SA1316 and 2SC3329 is even lower than the Rohm parts mentioned. I have yet to have the time to play with them.
