I soak my cables in liquid vaseline so that electrons flow smoother (much better than olive oil which goes rancid and makes the cables smell bad).
Probably because there is not much above that. Guitar speakers all have a restricted HF response.Interesting. In my limited experience that's true. Higher frequencies giving a "Bee in a jamjar effect" Although if micing a typical amp you don't get much out of the speaker above that ?
That would be the case if the amp's controls can't remedy. There are amps with limited tone controls, but an amp with typical 3-band EQ. should be able to get a reasonably "un-muddy" sound.And you can usually safely hpf at 150/200 Hz in most cases to avoid "mud'.
This has been my experience as well. The build quality and construction of the cable is extremely important especially if you are building your own cables. I have also noticed a difference in quality of XLR connectors. There are many "knock off" versions available these days. I'm currently upgrading all of my mic cables to Switchcraft AAA3MZ and AAA3FZ connectors mainly for their quality and mostly for ease of installation.We found no difference. Despite all of us actually expecting there to be at least some difference - feeling we should see something relatively clear like when we swap long guitar cables.
We ended up choosing only on the basis of workabilty and mechanical feel - ease of stripping and soldering, bend diameter. (mogami was it)
A few years ago, one of the assistants brought a U87 and its original screw-on swivel mount/cable to the workshop with the complaint that the mic was noisy.I have noticed small yet significant differences in mic cables over the years...it was always the no-name probably made=in-china cables that sounded a bit restricted....mogami, canare or belden brilliance sounded similarly good. I also remember once a 50 year old Belden 8412(?) cable had that restircted sound...due to aging, or due to type of insulation materials..I think insulation around conductors was rubber. I noticed the above during various system tests/troubleshooting. I think if I had the money and the need I'd do a super test but that would require a band and about 4 hours.....different mics, different cables on the mics, careful notes and then recording individual instruments as well as making a mix. A really good test is impractical. Simple testing against a good brand name cable can weed out the chud.
That's the problem with rumours. One person spreads it to thousands. Inversely, it takes a thousands bearers of the truth to convince a credulous mind.I have the MK67 kit attached to a U87ai. I read several people who said the sound improved significantly with a new cable (the one induced with the kit is a super long, ugly, and cheap). So I built a new 15 ft cable out of Gotham cable and nice connectors. Tested it out on acoustic guitar and vocal, and heard no difference. To confirm, I measured both with a pink noise source and they were identical.
Back in the 80s I wrote a magazine column disabusing popular audio myths. Many of these same myths are still going around today.That's the problem with rumours. One person spreads it to thousands. Inversely, it takes a thousands bearers of the truth to convince a credulous mind.
Not sure what came stock, but regardless of sound change, can't beat Gotham's GAC-7 in terms of usability. So many 7-pin cables are crap, the abomination that came with my recent Lewitt purchase is among the worst feeling cables I've ever encountered. Anyway, I won't derail us into the topic of meaningful differences in cablesI have the MK67 kit attached to a U87ai. I read several people who said the sound improved significantly with a new cable (the one induced with the kit is a super long, ugly, and cheap). So I built a new 15 ft cable out of Gotham cable and nice connectors. Tested it out on acoustic guitar and vocal, and heard no difference. To confirm, I measured both with a pink noise source and they were identical.
for a guy who has about 500ft of GAC-7 in use, I gotta say i do NOT like its memory due to it's cheapish outer insulation, i much prefer a cable that just lays where i put it, if i could find a softer more supple silicone clad cable that performs well id go that routeNot sure what came stock, but regardless of sound change, can't beat Gotham's GAC-7 in terms of usability. So many 7-pin cables are crap, the abomination that came with my recent Lewitt purchase is among the worst feeling cables I've ever encountered. Anyway, I won't derail us into the topic of meaningful differences in cables![]()
(...) even after i explain to them that their magic cable is connected to a wall outlet that has a 500' roll of 14-2 romex wire thats shared ground/unshielded running back to a service entrance panel that also isn't grounded properly (...)
Indeed! I’ve over 500ft. of Sommer tube mic cables in use and so far, it’s the only way to go for me. I still have 3 Gotham GAC-7 in use and they drive me up the wall every time I pull them out!for a guy who has about 500ft of GAC-7 in use, I gotta say i do NOT like its memory due to it's cheapish outer insulation, i much prefer a cable that just lays where i put it, if i could find a softer more supple silicone clad cable that performs well id go that route
+1 for the Sommer tube mic cable. Good quality, reasonable price, it is easy to lay and doesn't behave like an anaconda (in its puberty).Indeed! I’ve over 500ft. of Sommer tube mic cables in use and so far, it’s the only way to go for me.
You forget the silver in wall wires and the electric high tension links as well...Sadly you all were mistaken. There were a crucial element missing - a 200 euro worth wall power outlet, designed specifically for audio. Without it 5000$ cables cannot function properly.
Ask anyone.
Nuclear?! Nuclear??! Are you mad, sir? Only coal! Nuclear fission creates unpleasant, harsh electricity while coal gives nice, warm, analog feel to the current.You forget the silver in wall wires and the electric high tension links as well...
we could also ask the provider to install silver wires straight to the nuclear power plant...
