It was a good question from the OP ignoring the speed of electrical signal propagation through wires being extremely fast compared to the relatively pedantic audio wavelength/periods.
In other slower mediums sum and difference combinations of audio traveling over different path lengths (like through air) can interfere..... and for much higher frequencies than audio the propagation speed through wires can result in constructive or destructive interference (and more).
"No" was just my succinct answer to the original question. There is nothing wrong with more information but at some point it can get confusing "Blinding them with science".
Just to be clear you are comparing the speed of an analog audio signal passing through wire vs, MIDI digital bit stream passing through wire. Apples and Grapefruit... not the same. There is propagation delay in both the midi send end and midi receive end.
The delay has nothing to do with the length of the midi cable. I recall experimenting with sending MIDI signals through 100' long audio snakes with no appreciable delay (while I wasn't measuring for that, I just wanted to see if it worked).
Yes. Except that ime "propagation delay" refers only to the transmission of a signal in a cable (or eg optical fibre). But, as you point out, any delay of the type the OP has experienced is not down to the cable length (or construction fwiw).
