Hi to all, I had crazy busy week than nice but short vacation.
Back to our Mixbuzz500 stuff.....
OK....I think +48V somehow passed to input. Bad to hear about this.
Again!!!!, tabs for 51X rack, and never power on the rack before the module sits perfect inside the slot!
Something wrong happens inside your 51X rack, or maybe the module inserted wrong way.
+48V is far from input/output connectors. Strange.....
Yes. Take it out from PCB (desolder). There are I_IN and I_OUT pins of VCA.
Put in-between "fake unity gain resistor" with value=R3-R6. I.e. if R3=47K, and R6=jumper,
use 47K (DBX202C version); if 202X used, and r3=5k, r6=3k74, use 1k25 resistor.
Put audio board inside the rack, check if all sits fine, connect control board,
only after checking everything is right, power on.
Audio board's gain should be 0db (audio and control boards should be connected!).
Than, check the voltage at VCA's control signal pin, without makeup/compression.
It should be 0V. Power off, take "fake unity gain resistor" out, put VCA. It should work.
If not works, VCA probably (99%) is dead.
Good news. Use crocodile for -(common) probe of multimeter (in case of whatever);
maybe previous measures were wrong?
No, 48V is far from input/output pins. Very strange. Maybe.....
In case rack was powered, module got first (somehow????) +48V than the rest of voltages....
Kill me here, impossible, if all voltages reading OK at the card edge.
If module was reversed (pin 1 goes to pin 15)...but same, impossible!!!!!
Tony, I thought about this issue, one more hour and I will smoke-up like your THAT1246!!
BTW. The audio board's relays are in BYPASS in default state.
This means, to check the audio board, you have to connect control
(front panel) board. For ROUGH check, enough one audio and control board.
For normal test, BOTH audio and control boards should be connected!
/in case of whatever:
CTL1, SC1 goes to CTL and SC left, CTL2, SC2 goes to CTL and SC right.
Or vice verse, but don't mess say CTL1 with CTL2. This way compressor will work wrong.
See first posts of this thread.
Guys! What happens! Somebody PUT A SPELL on those freaky ribbons!!!!
2 ribbons FUBARu'ed for one week!!!!!!
C'mon, easy with'em![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
OK....The story is next. (a bit OT!) Me and my friend from Bardo Mastering
tested Sontec kit stuffed with different kinds of caps some years ago.
Relay based A/B box (my mastering console) and ATC monitors.
Monster/Kimber/etc super-duper BS wiring in case of whatever,
but I don't trust any hi-end cables except military silver-plated teflon isolated,
which never were rated as hi-end audio cables.
We found immediately that EQ stuffed with SilverMica "anti-oscillation",
or "feedback" caps, sounded better than other with NPO's, 63V.
I can hear it as more definite highs. More details. Less fog.
Again, I hate sound talks like punchy-crispy.
So, I ALWAYS use micas at important places.
Second reason, I have about 2 kg of low value SilverMica's from surplus
and (or thus) may be wrong![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Silver micas mostly have 7...10mm spacing for 47...82pf (C1); they fit fine on PCB,
maybe, bend leads a bit.
Up to you. I personally hate "useless" or "additional" components.
Audiopath should be short and simple as possible. Diodes can be installed on pcb,
there's a plenty of space. THAT1646 doesn't needs capacitors at it's out.
THAT1246's out bypassed with capacitor and it has -6db gain, so, no need for input capacitors as well
even in case of little DC offset at out of device connected to Mixbuzz500 input.
"Fool protection": install diodes. I prefer to check everything before putting module
in the rack and sleep good with mind of lack of additional components in my pure soundpath Mixbuzz![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Nope. IC8 (THAT1646) see at it's input: R7 in parallel to impedance of C3/C5, plus R5=68R,
plus output impedance of IC11B. It is less than 100R in 20-20Khz.
Lowering R7 to 1K: will give audible phase shift at low freq's and little (some db) drop at 20Hz.
Those who good with math can calculate/simulate. No noise floor improvement.
The noise floor actually caused by VCA's impedance...
I.e. using 4 paralleled 2181's and R3=5k IMHO not too bad solution![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
of dc offset at IC11b out,even in case VCA perfectly calibrated. VCA gain changes, offset changes a bit as well. Little DC offset appears especially when VCA gives positive gain.
IMHO, MixBuzz500 using necessary minimum of parts,
mods and tweaks are at your own rescue and taste, but....feel free to tell if there some ideas![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
In any case, this is build support thread;
for "mod" people: first build and make it working 100%, than mod at your rescue![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
but i definitely can see some smoke residue on the sides of the 1246 on each boards
(Rectification of the last post, it's the 1246 not the 1646!)....
Well i think one of the DBX is dead
Cry, without the chips but DBX in i'm reading 27v on the V+ pin,
i really don't get what happened, everything is fine in the box....
and the unit was working properly in the lab...
PS: I think there is a way to check the DBX, like its resistance?
hmmm, i Absolutely don't get it, i just connected the boards alone in the rack,
one board with chips out, all had good voltages on right pins,
and tried with the other one that had the components all in, and everything is fine,
no crazy voltages on the pins or whatsoever,
DBX getting correct voltages all Socket pins getting correct voltages and no Smoke
Huh Huh Huh Huh Huh Huh Huh
at least on one of the boards and Controller board not connected,
didn't check sound passing still but very Weird issue,
maybe a pin got shorted when inserting the card
Huh, Now i need to check all the configuration in the box and not out of it,
just to have a better look of that.
One of the ribbon cables had got damaged and the sidechain was going nuts.
C'mon, easy with'em
Will try to answer in Zen weird wayany suggestions on the silver mica caps?
some protection against 48V and RFI is suggested in the date sheet.
I would strongly recommand this modification for reliability:
look at page 9 of: http://www.thatcorp.com/datashts/THAT_1606-1646_Datasheet.pdf
line recievers/drivers:
THAT1246 IC1: some additional RFI protection look at page 4 and page 5 fig 4 of :
http://thatcorp.com/datashts/THAT_1240-Series_Datasheet.pdf .
As suggested do this directly on the connector.
The IC is protected against +48V on the input pins, so no worry there.
I also suggest to lower R7 to 1K for better S/N ratio.
Need some clarification, but, if you mean C3/C5, there will always be some tens of millivoltsSomebody tried to leave out (bypass) the coupling caps in front of the linedriver?
