Brizco said:
Looks great Brizco, may I ask where did you source the control knobs?
Mark
stereokillah said:AudioGimmer,
for your ratio check your resistor on the controle board
R65,72,73,77,78,79,80,82,85,86,90,91,92,93 if you've got the good value
on my pictures you could see one line with 620k diode 68k 270k and 510k and the second 620k diod 68k 510k and 270k
perhaps you did a error here.
dbeeson said:Closest store to you is Cambridge. I'm heading there this week and I'll get a part number for you.
Stereokillah, all resistors OK, and I checked the diodes, they are good too. Gotta do some work now, but will test again later today.
Thanks.
AG
Yes, it done by way to keep same amount of compression at different ratios.With a steady test tone input producing say 6-8dB or GR on the 2:1 ratio and selecting different ratios[ and not adjusting the threshold pot] the 2:1 setting still shows more GR than 4:1 which still shows more GR than 10:1
HOWEVER I then decided to measure the actual gain reduction that each ratio setting is actually producing [by setting up a steady GR of 4dB and then measuring the required increase in input level to give 3-4 dB output gain. The results:
2:1 = 2.4:1
4:1 = 3.7:1
10:1 = 6.5:1
So the compressor and the ratio switch seem to be working OK, just that increasing the ratio doesn't automatically increase the amount of gain reduction. [ which is what I was expecting ] The 2:1 and 4:1 ratios are pretty close, the 10:1 is a little gentle
In terms of the rest of the calibration, I get unity gain in/out, the GR meter is pretty accurate [using tones and some good VUs whilst testing the ratios] and the unit sounds gooooood!
Thats enough for tonight, thanks Stereokillah, for your help and useful suggestions.
Igor said:So the compressor and the ratio switch seem to be working OK, just that increasing the ratio doesn't automatically increase the amount of gain reduction. [ which is what I was expecting ] The 2:1 and 4:1 ratios are pretty close, the 10:1 is a little gentle
Pretty close. Try to measure with more gain reduction, or, maybe, check resistors
at ratio switch for Deutch precision![]()
OOPS. You mean 5532, right? OPA2604 will be fine there.I might consider swopping the 3352s for OPA 604s on the audio pcbs if they are just drop in replacements.
One last question about RV1 on audio PCBs. I set both my trimmers to 5K1 before I put them in. Is it necessary to adjust them in circuit with tones so that both sidechains are producing exactly the same control signal? What would be the best way to do that?
Igor said:OOPS. You mean 5532, right? OPA2604 will be fine there.I might consider swopping the 3352s for OPA 604s on the audio pcbs if they are just drop in replacements.
I'm using an original black can dbx 202 vca in my build.
Gain Control Constant: -6mv/db
Gain Control Input R: 197R +/- 2%
