Winetree
Got the 7 pin connectors for mic and PSU.
Can I use Mogami W3172 tube mic cable with 6 wires and shield?
Audio
1 = A- (gray) (connects to pin 3 of XLR at the power supply)
2 = A+ (white) (to pin 2 of XLR at the PS)
Center pin = audio ground (green) (to pin 1 of XLR)
Power
3 = B- (black [blue in the cable])
4 empty
5 = B+ (red)
Pattern
6 = P (yellow)
Shield to the chassis.
JW said:Don,
What is the difference between B- and "audio ground?"
You mean pin 1,no?idylldon said:I attached the audio ground to the B- pad/ground plane in the mic and then ran it to pin 3 in the XLR connector back at the power supply.
kante1603 said:You mean pin 1,no?
Udo.
Winetree said:Used 3-1k1 10 watt power resistors.
Winetree said:Hooked up the mics to the power supply. No load, no glow, no go.
Read the earlier posts. Looks like I'll be lookin for tubes.
kante1603 said:0dbfs said:Awww 680 grams. She's very cute.
And how have you named her?
not decided yet because I don´t know if it is male or female maybe "BLU47"?
Udo.
